btjones34711's avatar
btjones34711
Can you connect two AX6000 routers using "ethernet port aggregation"?
Is it possible to connect one (1) AX6000 to a second AX6000 that is setup in "Access Point Mode" using "Ethernet port aggregation"?  Something like the attached...
  • why don't you try it and tell us? Also, there may be something about that in the manual PDF. Look it up on what it supports
    • michaelkenward's avatar
      michaelkenward
      As microchip8 says, start with the manual.
      To finds that you will have to work out the model number. AX6000 is not a Netgear model number. It is a label that Netgear, and others, attach to hardware to describe wifi speeds.
      You could have a RAX120 or RAX80.
      If you visit the support pages:
      Support | NETGEAR
      you can feed in the model number and find all the documentation for your hardware.
