BelowTheBelt's avatar
BelowTheBelt
Cannot Connect To Roundcube Webmail. Various Errors On Login With RAX120 Router.
Router:  Model# RAX120-100NAS   AX6000
Gateway/Router To Internet:   TMobile 5G Gateway
Incompatible/Problem:  Cannot Login To Roundcube Webmail with router connected to gateway
I have TMOBILE internet services provided via a 5G Wireless gateway.
Without the RAX120 connected via ethernet to the gateway, I can connect to my Roundcube Webmail service without issue.
However, the 5G Gateway does not offer USB drive support.   As a result, I added the   RAX120-100NAS   for network drive support.
Almost all is good.   I can connect to:
Network Printer
Streaming Services
Gmail
Ymail
Network drives.
ISSUE
I cannot login to ROUNDCUBE webmail services with RAX-120 connected to gateway.
From my laptop, I can connect if I:
1.  Switch from RAX-120 WIFI connection to my mobile hotspot, I can login.
2.  Remove RAX-120 ethernet connection to gateway, and wifi to gateway, I can login.
3.  Disconnect my wifi connections and utilize my laptops modem, I can login.
I have tried all 3 browsers:
1.  Edge
2.  Chrome
3.  Firefox
I have tried another laptop.
All to no avail.
These are the 2 error messages I receive ONLY WITH THE RAX120 connected to the gateway:
  • michaelkenward's avatar
    michaelkenward
    It sounds like you are piling router on router. That is an invitation to chaos.
    Two routers on your network can cause headaches. For example, you can end up with local problems with addresses on your network. Among other things, the other router can misdirect traffic to addresses that the Netgear router usually handles, such as routerlogin.net or the usual default IP address for a router, 192.168.1.1.
    I suspect that this is what gets in the way of your webmail services.
    This explains some of the other drawbacks of NAT conflicts.
    What is Double NAT? | Answer | NETGEAR Support
    It is often easiest to use just one router and to set up the second router as a wifi access point (AP) with a wired connection to the main router. Netgear advises this, as does just about every site you will visit.
    How do I change my NETGEAR router to AP mode? | Answer | NETGEAR Support
    But that has its own drawbacks:
    Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
    It may be possible to put the modem/router into modem only (bridge) mode and then to use the second device as the router.
    Just another user with time on their hands.
    • BelowTheBelt's avatar
      BelowTheBelt
      In an attempt to troubleshoot, my friend lent me an older TP Link Router....Archer C90 AC1900.
      This worked like a champ right from the get go.  No issues with any webmail site.  No issues with access to the network storage.
      So, maybe I am sticking with the TPLINK router and sacrificing some speed.
      • FURRYe38's avatar
        I would give the DMZ on the host gateway router a try with the RAX120 and see if this helps.
        Your double NAT condition will impact how the RAX120 and your web mail services work in that condition which should be avoided, either by using the DMZ or in AP Mode with the RAX120.
