Mikemairangi's avatar
Nov 10, 2024
Cannot login to router
I need to set up port forwarding yet cannot log into my router. I get the the login page enter my credentials and my netgear account details and then get an error message saying sorry please try again. I am at my wits end trying to access the thing!?!
  • plemans's avatar
    What router do you have?
    are you using its ip address or the routerlogin address?
    Have you tried simply factory resetting and reinstalling?
    • Mikemairangi's avatar
      Mikemairangi
      Tutor
      It's a Nighthawk AX6 AX5400 WiFi Router (RAX50v2). I've tried both the IP address and the login url. Both fail when I enter my username and password. I didn't want to do a factory reset and I've configured a couple of SSID's and had fun and games setting it up at the outset as it's a non-ISP provided router.
      • michaelkenward's avatar
        michaelkenward
        What connects your router to the Internet?
        Many ISPs like to inflict their own choice of modem/router combinations on customers.
        Two routers on your network can cause headaches. For example, you can end up with local problems with addresses on your network. Among other things, the other router can misdirect traffic to addresses that the Netgear router usually handles, such as routerlogin.net or the usual default IP address for a router, 192.168.1.1.
        This explains some of the other drawbacks.
        What is Double NAT? | Answer | NETGEAR Support
        Unless you have specific reasons for using two routers – to create two separate networks for example – it is often easier to use just one router and then to set up the second router as a wifi access point (AP) with a wired connection to the main router. Netgear advises this, as does just about every site you will visit.
        How do I change my NETGEAR router to AP mode? | Answer | NETGEAR Support
        But that has its own drawbacks:
        Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
        It may be possible to put the modem/router into modem only (bridge) mode and then to use the second device as the router.
        Just another user with time on their hands.
