dmystic1
Dec 29, 2018Apprentice
Can't download VPN configuration files- RAX80
I guess this is a problem with firmware on other models, just saying it's a problem with the latest router with the latest firmware!
Christian_R
Jun 18, 2019NETGEAR Employee Retired
Hi skapernicus - Would you mind confirming the firmware version the router is currently on.
~Christian
- skapernicusJun 18, 2019Tutor
Firmware Version V1.0.1.58_1.0.24
*Update* - I contacted Netgear support and they weren't able to assist me much with the matter via online chat support. The issue was escalated and they called me back to explain that the OpenVPN configuration files can NOT be downloaded via the remote mgmt interface. "https://<your.ip>:8443". The configuration files must be downloaded only when the mgmt UI is accessed from the LAN. (192.168.1.1)
- schumakuJun 21, 2019Guru - Experienced User
skapernicus wrote:*Update* - I contacted Netgear support and they weren't able to assist me much with the matter via online chat support. The issue was escalated and they called me back to explain that the OpenVPN configuration files can NOT be downloaded via the remote mgmt interface. "https://<your.ip>:8443". The configuration files must be downloaded only when the mgmt UI is accessed from the LAN. (192.168.1.1)
This is clealry a bug, it was no problem downloading the VPN configs on earlier Netgear Nighthawk routers also using the WAN/Internet remote access. Christian_R can you push this to be fixed please?
- Christian_RJun 24, 2019NETGEAR Employee Retired
Hello skapernicus & schumaku,
I have reported the issue to engineering and they will be looking into it.
~Christian
