Autumn47's avatar
Autumn47
CAX30 AX2700 big drop in speed
I have a 1gbps internet plan for home and have noticed consistent slow speeds. I decided to call the cable company's technican and his test results were as below
1, Co-axial cable to his hand held testing device: download MAX 988mbps, AVG 905mbps.
2. Co-axial to netgear CAX30 AX2700 to his hand held device (via both cat5e and 6) : download MAX 280mbps, AVG: 215mbps
3. Overwifi : download ~ 250mps
Questions
1. Anyone has an idea as to why there would be such a huge drop in speed (from 980 to 280)?
2. Any suggestions to bring the speed as close as possible to the test results from the co-axial cable to the testing device?
Thanks
  • plemans's avatar
    did you try a simple factory reset/reinstall of the router?
    • Autumn47's avatar
      Autumn47
      Yes I did the reset and no change in the speed. Also tried playing around with the channels..to no avail.
      • plemans's avatar
        what speeds do you get?
        Not the tech
