Ctcomsa
Sep 06, 2021Aspirant
CAX80 test speeds
hello everyone i'm still waiting on netgear to get back to on support i emailed them because the phone support tells me don't worry anything else your online. i get different issues all the time I'...
Ctcomsa
LG gram
i just thought the 2.4 was way slow my smart house isnt to smart since I got the ax8
i cant even connect with the app unless I reset everything then its good for almost a day.
Sep 06, 2021Guru - Experienced User
Ctcomsa wrote:
LG gram---what wireless card is in it? how are you testing speeds? have you tried other devices? Also, how far away from the router are you? 5ghz speeds drop off quickly.
i just thought the 2.4 was way slow---its is slow. its great for Iot device but a bit lackluster for streaming. my smart house isnt to smart since I got the ax8---what do you mean your house isn't to smart since you got it?
i cant even connect with the app unless I reset everything then its good for almost a day.---connect with the nighthawk app? I don't use the app a whole lot but have you tried a couple devices to see if its a device issue? I usually just connect via the browser
