Ctcomsa
Sep 06, 2021Aspirant
CAX80 test speeds
hello everyone i'm still waiting on netgear to get back to on support i emailed them because the phone support tells me don't worry anything else your online. i get different issues all the time I'...
michaelkenward
Sep 07, 2021Guru - Experienced User
The CAX80 in your subject is an "AX8 AX6000 WiFI Cable Modem Router". It isn't quite the same as the Nighthawk WiFi Routers covered here.
You might get more help where its users hangout, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Cable Modems & Routers
- CtcomsaSep 07, 2021Aspirant
Thanks
