SanderWolf
Oct 31, 2020Aspirant
Circle stops working on RAX75
I'm running a nighthawk RAX75. I have the latest firmware. I am using the built in circle.
Ever since I updated to the new firmware Circle doesn't work consistantly. It stops enforcing bedtimes and showing usage. A router reboot might re-enable it for an hour or so, but then it stops working again.
What should I do?
- Christian_RNETGEAR Employee Retired
Hi SanderWolf,
You may check to see if your router is due for a firmware update. The article below may help address your history usage issues.
https://support.meetcircle.com/hc/en-us/articles/360026374272-Missing-Usage-or-History-Issues
Christian
- SanderWolfAspirant
I did check the firmware -- I'm at the latest.
Hi SanderWolf,
Did you have a moment to try the suggested steps from the Circle article?
Christian
