Windbreaker1976's avatar
Jun 22, 2020
CM700 Cable Modem Loses Connection to AX12 Nighthawk Router Randomly
Hello,
The subject pretty much says it all. Every so often, sometimes a couple of times a day, sometimes a couple of times a week, my cable modem and router stop talking to each other. The ethernet light on the modem goes dark and all devices connected to my router either wired or wireless lose access to the internet. Sometimes the first reboot fixes it. Sometimes the second reboot fixes it. Seems pretty random. I'm replacing the network cable today to see if that's the issue as it's the lowest cost denominator but any other suggestions? Anyone else experienced a similar issue they found a solution to?
Thanks!
  • FURRYe38's avatar
    Does a wired PC directly to the modem do the same thing?
    Swap out the LAN cable between the modem and router. CAT6 is recommended.
    Has a full reset on the modem and router been performed and setup from scratch?
    • Windbreaker1976's avatar
      Windbreaker1976
      With respect to PC connected directly to modem it's hard to figure that out as we have so many computers and devices running off that router and I can go days without it happening. I have the new cable so the next time it happens I'm going to swap out the cables and see if that fixes it rather than a couple of reboots of the modem. I know I've reset the router a few times but not sure about the modem. Probably not the modem, however.
