jtlynn23's avatar
Jul 09, 2020
Dead Nighthawk RAX35 - Support Ticket Open, Netgear Unresponsive
I have a RAX35 router that will not broadcast at all.  I get a power light and nothing else.
I opened a service ticket with Netgear Support at www.support.netgear.com.  I got a quick response from an agent with troubleshooting tips (including hard resets, etc etc), none of which worked.
I updated my ticket several times over the past week, asking for Netgear's recommendations and/or a replacement for my hardware and I have heard nothing.
Is anyone at Netgear support following up on tickets?
  • plemans's avatar
    have you tried recovery via tftp?
    are you on windows? if so, follow this guide
    https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
    just make sure you enable tftp
    https://www.thewindowsclub.com/enable-tftp-windows-10
    and here's a video walk through.
    https://www.youtube.com/watch?v=R9DLrLQrpaw
    and if that doesn't work, you can try using nmrpflash
    https://github.com/jclehner/nmrpflash
    another thing to check into is many don't use the proper netgear support. They google and get the wrong site/scam site.
    click mynetgear at the top. register an account and the device. From there you contact support.
    If that's what you did, maybe a moderator can help. Christian_R   olympos1625
    • jtlynn23's avatar
      jtlynn23
      Tutor
      Thanks.
      My expectation is that a Netgear agent will respond to the ticket that I opened specifically to address this problem.
      I have an open ticket and I am simply waiting for someone in Netgear support to do their job.
      • plemans's avatar
        jtlynn23 wrote:
        Thanks.
        And they might. Or it might take a while since they're so backed up. Or it might be never if you didn't go through the proper support channels.
        Not out a whole lot to try fixing it while you wait.
        Plus this is the community forums. There are a couple moderators on here but its for the whole site so they're even more backed up than support is.
