shadowb
Jul 16, 2024Aspirant
DLNA server not found from wifi devices on Access Point
My primary RAX50 is on one end of the house and the second RAX50 is in AP mode at the other end of the house connected via Ethernet cable. I run Servio DLNA on a computer connected to the Prmary router. All TVs and Firesticks wifi connected to the Primary router see the DLNA. None of the TVs and Firesticks wifi connected to the RAX50 in AP mode see it. What do I need to change? Ive read lots of similar posts but havent found a solution for my problem.
Hi, this is my second answer:
I search around and saw at the release of the predecessor Firmware 1-0-12-120 the issue "
- Fixes the issue where multicast packet failed to forward between Wi-Fi and Ethernet clients."
https://kb.netgear.com/000065385/RAX50-RAX50S-Firmware-Version-1-0-12-120
I tested now by downgrading to this version: the problems encountered in my former post (and maybe connected to your problem) have gone.
My guess: maybe the solved issue in 1-0-12-120 has been reopened in V1.0.16.132
How is AP mode configured on the 2nd RAX in AP mode?
FW versions the same on both?
- shadowbAspirant
What should I be looking for configuration wise? All I did was set mode to AP. Didn't change anything else except SSID and password.
Ethernet cable from Primary router is plugged into Ethernet port on AP router (I tried plugging into Port 1 with no difference).
I also tried making the SSID the same as the Primary - no help.
Which configuration settings are involved?
- shadowbAspirant
Firmware levels the same:
AP router V1.0.16.132_2.0.92
Primary Router V1.0.16.132_2.0.92
- metroboulotdodoAspirant
(Sorry, no solution)
I encounter a problem maybe related:
1 Router and 2 APs (one RAX50)
When connected to RAX50, no DLNA Renderer or DLNA Server are found though there are some on 2 QNAPs/ 1BananaPI. Only Airplay Service is detected.
When connected to other AP, everything is found.
(Connecting back to RAX50 with DLNA Client opened, the former detected DLNA Server can be used, but after a refresh it wouldn't show up again).
(Network configuration is quite simple: no VLAN or strange settings made)
My guess: RAX50 could have some problem with dealing with DLNA Broadcasts/UDP Packets. Very old power line adapters had those problems, I remember.
Solution: none 😞
- shadowbAspirant
Thanks for your information. I did a workaround by adding an Ethernet adapter to my Fire Stick and using a wired connection. All DLNA works now. Netgear obviously has a problem with DLNA on the RAX50 series.
