dmystic1
Jan 26, 2019Apprentice
Do I need a RAX12?
So I just bought a RAX8, is it worth it to get a RAX12 thru the beta program (making monthly payments)?
IrvSp
Jan 26, 2019Master
Might want to read this, https://www.consumerreports.org/wireless-routers/wifi-6-router-is-it-time-to-buy/.
dmystic1
I just want to know if the RAX120 has a major advantage over the RAX80. I don't need it, I already own the later.
- michaelkenwardJan 27, 2019Guru - Experienced User
Do you have any problems with your current system that you want to fix?
- microchip8Jan 27, 2019Master
you'd be beta testing. These devices are based on draft and have quite a few bugs in their firmware I suspect. Non to mention the price for them and (virtually) no AX clients either. "Future Proof" is a strange thing. If your RAX80 is doing well and you have no bottlenecks, I suspect you need to have the RAX120 because of "oh, shiny, faster and newer (and based on Qualcomm than **bleep**ty Broadcom :P)"
- myerswJan 27, 2019Master
Ah yes the shinny penny syndrome. You can always chase the rainbows for that pot of gold.
There is always going to be something bigger, faster, better then what you currently have. In this case the standard is not even finalized and are there any client support? Not much.
Real question is why do you think you need it?
