Moose-Squirrel's avatar
Sep 18, 2022
Enable AX first time issues
I've had AX enabled and never detected it as an issue until today when setting up a laptop with new intel wifi that is supposed to handle AX. Turns out others are having issue too. Oddly it would connect on guest networks but not 2.4 or 5G.
And still it has the annoyance of picking the wrong device type under attached devices and occasionally changing the device on its own.
And now I have another question which I've searched the manuals and find no explanation for. On the Advanced/Advanced Home page under the networks there is "Wireless AP" On.  What is the meaning of that?
  • plemans's avatar
    For your intel card, go directly to the intel site and get the driver. Tends to work better than the driver released to windows.
    in terms of the AP on, it means the wifi is broadcasting basically. (simplified version)
    • Already got the intel driver and did not help. Odd that all my other devices do not complain about AX or have trouble connecting with it turned on.
      They surely could have used better words to say the wifi is on since AP also represents so many other things, especially when you search the manual.
      • plemans's avatar
        What intel card is it?
        Usually if only 1 device is having an issue, its more related to something with that device versus the router.
