Samuel_Chow
Jan 18, 2021Aspirant
Error: Unable to establish WAN aggregation.
Hello,
Anyone have idea why i keep getting this error message?
"Error: Unable to establish WAN aggregation."
I have tried to plug in the plan cable in to
- Multi-gigabyte+WAN
- WAN+LAN1
- LAN1+LAN2
Still cannot get it set up as WAN aggregation.
I am using a supplier modem, the two both LAN cable is working.
Sorry if i post a redundant post. The firmware I'm using is V1.2.0.16.
What supplier modem are you using?
- Samuel_ChowAspirantHi, thank you for your reply.
The modem I use is provided by my internet supplier, it’s Huawei echolife hg8040h5.
Maybe this is the problem?
I am thinking of getting the CM2000 but I am not sure if this is a must for WAN aggregation, since this product don’t even sell in HK- plemansGuru - Experienced User
You'd have to check if the cm2000 was supported for your isp. If you have the hg8040h5, you're on fibre.
And I couldn't find if that gateway even supports port aggregation.
