pmokover
Feb 27, 2021Tutor
Ethernet Ports on RAX50 (AX5400)
Do the four Ethernet ports on the RAX50 (AX5400) router support PoE or PoE+? According to the specs on the Netgear website they do. That would be great if true but I'm guessing it's just a typo. See attached photo.
(Note: I am asking about PoE (Power over Ethernet), not PPPoE which is a different thing.)
Thanks!
> [...] See attached photo.
Which you found where, exactly? (Thanks for the helpful link.)
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get some. Read. Look for "PoE". (Prepare for
disappointment.)- Razor512Prodigy
The RAX50 does not have any POE ports, basically is is a single gigabit WAn port, and 4 LAN ports each at 1GbE.
If you need POE, then you will be stick with either getting PoE injectors or buying a basic POE switch.
If you end up going the PoE switch route consider getting something slightly higher end so that you have more room to grow.
