Llamaduck
Mar 05, 2025Aspirant
Frequent disconnects with nighthawk ax6 5400
I previously had a netgear router that worked well until I updated the firmware. I replaced the router with a new ax5400 and the internet connection will drop randomly. It seems to happen most with our phones and less with other devices. I've tried smart connect both on a d off and checked the firmware is up to date. Can I get some advice? I'm not a network expert so hopefully this is an easy fix.
1. what modem/gateway is it connected to?
2. what router is it? Those are speeds/references, not model numbers.
3. what firmware are you on? "The latest" isn't always the latest or has other issues.
4. Wired devices don't drop? Just wireless?
- LlamaduckAspirantWe have fios but I can't find a model #, possibly it's on the back but it's wall mounted so I don't want to mess with it.
Netgear model rax50v2
Firmware 1.1.4.28
All my other wireless devices are OK except for 2 android phones.- FURRYe38Guru - Experienced User
Any chance Protection Engine is enabled on the RAX router?
