Dauhee's avatar
Dauhee
FW V1.0.4.76_10.1.82, R8000 - static IPs not being handed out as configured
Hi,
I have static IPs assigned but some are not being handed out - has anyone else seen issues? The IPs that are not being set are for devices passing through EX7000 extender - yes I am using the virtual  MAC as that is what the R8000 sees. It seems to be intermittant which is screwing things up for me. They will work fine then get a different IP that is not the one I have set.
I have tried rebooting both router and extender
  • FURRYe38's avatar
    Static IP addresses on set ON devices. IP address Reservations are set ON the router.
    Has this been a problem recently or has this worked up to a certain point then failed?
    • Dauhee's avatar
      Dauhee
      yes thats it, configuration regarding reservation of IP set in "LAN Setup" against specificied MAC addresses is not being adhered to.
      This functionality worked without issue on DD-WRT, I have just recently put stock V1.0.4.76_10.1.82 on and am experiencing the issue
      • FURRYe38's avatar
        Might revert FW version to something prior. Resent FW has not been good for users.
