gblss
Jan 13, 2021Aspirant
Guest vs. Primary Wireless
Hello,
I have the above mentioned router set up with wired and wireless connections. New router current firmware. I have an microsoft surface on windows 10 that connects and works fine using the 5g guest connect. When I simply change the wireless network connection on the surface to the primary 5g wirless connection, I lose connection to the device from other computer on the same network. Guest network 5g - pings and works fine. Pirmary wireless 5g network no - ping no work. No other changes are made to any device or software. What could be causing this? Thanks in advance.
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's impenetrable community structure.)
You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
Nighthawk Routers with WiFi 6 (AX) - NETGEAR Communities
I will ask the Netgear moderator to move your message. - gblssAspirant
Is anyone going to reply on this. Brand new router no help?
- NewfiedroolVirtuoso
What bandwidth are you using on the 5Ghz channel?
- gblssAspirant
