Omar-'s avatar
Omar-
How many RAX10-100NAS can be managed from a single web interface?
We need to buy several AX1800 (RX10) Wi-Fi routers and put one in each site. can someone tell what is tha max number of this router can be managed from a single web interface? for example : we would like to see all of them and if one goes offline in a single web interface
Thanks
  • FURRYe38's avatar
    Remote management using routers web page is no longer supported. Only remote management is used thru the Nighthawk app.
    When older routers supported remote web page management, only could access a signal router per site at a time.
    • Omar-'s avatar
      Omar-
      Thanks! do you know the max number of routers I can link to nighthawk?
      also is there any current netgear router that supports both web interface and app management?
      • FURRYe38's avatar
        All NG routers have a web UI management page. Just have to be locally connected.
        I believe you can have many routers connected to the NH app. Not sure how the app handles same model router though. I presume it will separate them due to the serial number being different.
