rigram's avatar
rigram
I can only make WiFi calls when I disable DoS and Port scan protection
Although this thread is closed - I have exactly the same problem as initially logged with WiFi calling.
I can only make WiFi calls when I disable DoS and Port scan protection (I do however have Sip ALG disabled).
I have current firmware for Nighthawk RAX80 ver 1.0.10.140
Ideally I would like to turn back on the DoS and Port scan protection - however if I do this WiFi calling stops
