eric_bor
Dec 06, 2022Tutor
Interesting problem connecting to routerlogin.net
Hi, I have a RAX54 and I'm able to get it setup and configured but I run into a weird problem where I can no longer access the routerlogin.net page after I've completed the setup and make a few upda...
Dec 06, 2022Guru - Experienced User
What modem/gateway is it connected to?
Are the devices directly connected to it or running through a switch/another router?
- eric_borDec 07, 2022Tutor
It's just connected directly to the Fios ONT ethernet port. I had ethernet from ONT -> wire -> router -> wire -> PC. No other switches involved (during set up). Eventually, I am hoping to connect everything else up.
- plemansDec 07, 2022Guru - Experienced User
What fios ont is it?
What happens if you leave the ip address on the 192 address?
The ONT is verizon i211ml. What would happen is my family would kill me since I have everything already configured for 10.x and things would not be working for some time. đ I guess I could try that but I previously had R7800, R7450 and R7000 with no problems.
