eric_bor
Dec 06, 2022Tutor
Interesting problem connecting to routerlogin.net
Hi, I have a RAX54 and I'm able to get it setup and configured but I run into a weird problem where I can no longer access the routerlogin.net page after I've completed the setup and make a few upda...
Dec 06, 2022Guru - Experienced User
What modem/gateway is it connected to?
Are the devices directly connected to it or running through a switch/another router?
eric_bor
Dec 06, 2022Tutor
It's just connected directly to the Fios ONT ethernet port. I had ethernet from ONT -> wire -> router -> wire -> PC. No other switches involved (during set up). Eventually, I am hoping to connect everything else up.
- plemansDec 06, 2022Guru - Experienced User
What fios ont is it?
What happens if you leave the ip address on the 192 address?
- eric_borDec 06, 2022Tutor
The ONT is verizon i211ml. What would happen is my family would kill me since I have everything already configured for 10.x and things would not be working for some time. đ I guess I could try that but I previously had R7800, R7450 and R7000 with no problems.
I should also mention that the USB shared drive still works ok.
