eric_bor
Dec 06, 2022Tutor
Interesting problem connecting to routerlogin.net
Hi, I have a RAX54 and I'm able to get it setup and configured but I run into a weird problem where I can no longer access the routerlogin.net page after I've completed the setup and make a few upda...
eric_bor
Dec 07, 2022Tutor
Follow-up: I had a chance to try it with 192.168.1.1 and that has the same issue. I'm also getting the dup ack in Wireshark there too.
Dec 07, 2022Guru - Experienced User
When you reset it (to access it and change lan) , did you test after each change at what point the gui became in-accessible?
- eric_borDec 07, 2022Tutor
Soooo.... this makes no sense to me at all but the issue is/was: *drum roll*
A Sandisk USB drive/stick plugged into the USB port!?!?!?
I reconfigured everything, one step at a time, rebooted, cleared cache, etc. after each step. I made it all the way to the finish line - it was working, awesome! Put it back into it's 'home' and plug the USB drive back in - *bam* connection reset.
The only explanation *sort of* that I could think is that, once it gets plugged in, the USB drive is getting published as a media server and everything on the network starts to scan it and the router throws up a block on traffic to the IP altogether. I don't know - it's crazy! My next step would be to plug in the USB and disable the media server but I've already spent too much time troubleshooting and I have ethernet cables going all over my house. If I have a free minute, I'll try that out and see but, as of now, I can access the routerlogin page *and* type this message. Crazy, I know!
Thank you, plemans for hanging in there with me on this! Not a great conclusion but I got it working. I'll also update my ticket with Netgear support.
- plemansDec 08, 2022Guru - Experienced User
Glad to see it was a usb drive causing issues. I have had that happen long ago with an old school cisco router that crashed because of the media on a drive. Same kind of issue
