Dustin_V
Nov 07, 2018NETGEAR Employee Retired
Introducing The Nighthawk AX8 WiFi Router - The New Era of WiFi
NETGEAR is leading the New Era of WiFi with our new Nighthawk AX8 8-Stream WiFi Router! The Nighthawk AX8 is NETGEAR’s first WiFi Router to support Wi-Fi 6, the latest generation of Wi-Fi te...
Daniel84
Nov 27, 2018Tutor
I bought this router in USA, However I need. Power adapter for Europe, can I get this accessory somewhere?
William10a
Nov 27, 2018Master
You should be able to find a power adaptor to fit the country's outlets with the correct pin and voltage rating to power the router at a electric supply house in that country or a travel converter.
- Daniel84Nov 27, 2018Tutor
- William10aNov 27, 2018Master
Sorry a 12 volt 1 amp(12 watt) adaptor will not work the netgear power supply is rated at 19 volts at 3.16 amps you would need a laptop type adaptor.
