Dustin_V
Nov 07, 2018NETGEAR Employee Retired
Introducing The Nighthawk AX8 WiFi Router - The New Era of WiFi
 NETGEAR is leading the New Era of WiFi with our new Nighthawk AX8 8-Stream WiFi Router! The Nighthawk AX8 is NETGEAR’s first WiFi Router to support Wi-Fi 6, the latest generation of Wi-Fi te...
Daniel84
Nov 27, 2018Tutor
William10a
Nov 28, 2018Master
Sorry a 12 volt 1 amp(12 watt) adaptor will not work the netgear power supply is rated at 19 volts at 3.16 amps you would need a laptop type adaptor.
