todd1010's avatar
todd1010
Apprentice
Feb 17, 2021
iPhone 11 Pro Max not connecting to wifi; suddenly!
Not sure what is going on here but my wifi SSID’s are visible, I can connect on other devices and my phone has been connecting to it perfectly fine for the last year and a half.
All of the sudden today it asks for the wifi password and after I enter it it says unable to connect. Out of nowhere this just started.
All other 32-33 devices in the house are connecting fine.
My router is a Netgear RAX120
  • Also, on my phone I’ve reset network settings to see if it would fix itself and nothing changed along with restarting my phone.
    • antinode's avatar
      antinode
      Guru
      > enter it it says unable to connect. [...]
         Recent iOS update?  Is Access Control enabled on the router?
            https://support.apple.com/en-us/HT211227
         Not all on the same radio band?
         Not RAX120v2?  Look for "Model" on the product label.  Firmware
      version?  Connected to what?
      • todd1010's avatar
        todd1010
        Apprentice
        iPhone has been on 14.4 the latest update since it came out without issues.
        The Netgear router shows no update either.
        I’m interested in this Access Control! I need to find what this is and how to figure out if this is keeping it from connecting.
