illiad's avatar
illiad
Tutor
Apr 20, 2022
Is it possible to transfer files from connected USB drive wirelessly to my android?
I have seen many post about using a Netgear router as a simple way to connect SSD storage.
eg https://dongknows.com/turning-wi-fi-router-usb-port-into-a-nas-server/
(this is a 2 year old post, so too old??)
there is an app for android called 'airdroid'  that makes it possible using a web browser, but I would like to be able to transfer files to and from the USB connected to the router,  so not needing to switch on my computer! 🙂
  • plemans's avatar
    You should be able to do this. I routinely transfer files from my phone to my nas. Its as simply as moving them using whatever app you choose on your phone to the hard drive. the phone should be able to see it as a network drive.
    • illiad's avatar
      illiad
      Tutor
      ** to clarify ***
      I DO NOT HAVE A NAS...
      I have a HDD, inside a case, powered externally. Please search the 'startech' website for s351bu313
      this is connected to the Nighthawk RAX50 using the supplied USB 3.1 Gen 2 cable.
      please  check my question 🙂
      • plemans's avatar
        I understand you don't have a nas.
        Attaching the hard drive to the router makes a simple networked folder/drive. Same thing as a basic nas. (nas=network attached storage)
        Concept is really similar. I usually use ES file explorer or File manager and then just add the networked drive in its settings.
