gdahl7's avatar
gdahl7
Follower
Nov 26, 2020
is the NIGHTHAWK® AX5200 AX6 DMZ capable
Hello,
I would like the option for a DMZ. Will the NIGHTHAWK® AX5200 AX6 do this?
Thanks,
Gary
  • michaelkenward's avatar
    michaelkenward
    Visit the support pages:
    Support | NETGEAR
    and feed in your model number and check the documentation for your hardware.
    You may have done this already, but I can't tell from your message.
    You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
    Nighthawk Routers with WiFi 6 (AX) - NETGEAR Communities
    Is the Model: A7000|Nighthawk AC1900 WiFi USB Adapter - USB 3.0 listed in your footer involved in this in anyway? Or did you just click the first thing that popped up when you wrote your message?
