rhys375
Apr 29, 2020Tutor
Is the Nighthawk RAX80 compatible with Australian FTTC NBN?
Hi all,
I recently (FINALLY) got FTTC NBN activated at my home. In preperation of this event (upgrade from ADSL of less than 4 Mbps Down) I splurged and bought the Nighthawk AX8 router for my home network. As far as I could tell when I bought it, the NBN connection box does all of the decoding and all I needed was a modem/router with an 'Internet' or 'WAN' port, which the AX8 has.
After about 2 hours with TPG online tech support changing settings we were unable to get it to talk with the NBN connection box. Meanwhile, the include free TP Link router is plug and play and works 100% perfectly. Only issue is that this free router is, as expected, garbage. The internet wifi speeds are a solid 10+ Mbps slower than the AX8 and the range is nowhere near as good.
I can get the AX8 work in access point mode, but it leaves me with a whole extra TPG router in the mix adding to a higher ping, more cables / clutter / complexity / power consumption etc.
I would love to know if anybody has the AX8 router connected to an FTTC connection on the Australian NBN, and if so what settings did you have to change to get it working?
P.S I have tried the auto setup genie and it cannot detect an internet connection at all which is strange because as soon as I swap from router mode to AP mode it does detect internet and broadcasts perfectly. I have tried both plugging NBN connection box directly into the 'Internet' port of AX8 and also running an ethernet cable from the working TP link modem's LAN port into the 'Internet' port of the AX8 without sucess.
Any help would be greatly appreciated
I believe the information I gave regarding the NBN NCD providing an ethernet connection is correct based on reading I had been doing accross multiple forums. As I said, it takes the VDSL signal from the FTTC splitter in the pit out the front of my house and effectively acts as a modem but it is not directly accessible by the user as it has no built-in PPPoE authentication ability so you cant just plug directly into it as far as I know. So yes, in fact all I needed was a router but I was seeking guidance on how to set it up to authenticate PPPoE with my ISP.
I am writing here for any future readers to tell you YES! It is compatible! All the other info I could find was for lower tier Netgear routers and the settings you need to alter are in different directories for the Nighthawk AX8.Interestingly, you do NOT need a password to satisfy your login credentials. On the internet setup page on the router home IP address just put in your username without the "@tpg.com.au" suffix. Set the ISP drop down menu to "PPPoE", leave password blank, leave service name blank, connection mode should be 'Always on', Get IP dynamically from ISP and I use 1.1.1.1 as my primary DNS and 8.8.8.8 as my secondary, though this can also be left as get automatically from ISP if you want.
All of that is straightforward, but heres the rub. Alone, it is not enough. You also need to alter the VLAN setting and there is a little trick to that. In the AX firmware you need to select the 'Advanced' tab at the top left of the page. Then select 'Advanced Setup' from the menu on the left hand side and finally select 'VLAN/Bridge Settings'. I dont know enough to say exactly WHY this set-up works, all I can say is that it does. The VLAN ID of 2 is specifically for TPG and I believe other ISP's use other VLAN ID's. As you can see, I have Port4 on its own group and all others on a different VLAN group. The reason for this is, any port that is associated with the group that has a VLAN ID of 2 and priority of Zero becomes inaccessible after you set this up. I was getting very frustrated because once I was swapping all my ports onto this VLAN Tag the internet light on my router was going from amber to white but it became impossible to access my router or internet via any IP address or even routerlogin.net. However, if I left my active ports on a secondary VLAN Tag with a priority of 2, BINGO, my AX8 was now working with no TP-LINK modem, my ping has dropped, my wifi speeds increased from about 37 Mbps to 47 Mbps on back-to-back runs between the budget router included from TPG to my AX8 Netgear router. Also wifi range was SIGNIFICANTLY increased and of course the addition of WIFI 6 which my next phone will almost certainly have.
I hope this info can help someone else. I probably lost a few years of my life trying every setting I could and resetting the router a million times but it was worth it in the end.
rhys375 wrote:
I recently (FINALLY) got FTTC NBN activated at my home. In preperation of this event (upgrade from ADSL of less than 4 Mbps Down) I splurged and bought the Nighthawk AX8 router for my home network. As far as I could tell when I bought it, the NBN connection box does all of the decoding and all I needed was a modem/router with an 'Internet' or 'WAN' port, which the AX8 has.The RAX80 is a router. It usually sits behind a modem of some sort.
The type of modem depends on your internet sevirce, cable, DSL, fibre, something else.
FTTC NBN will need something to feed Internet to the RAX80.
Start here:
What is an NBN network and is my NETGEAR DSL modem router compatible? | Answer | NETGEAR Support
Note that it does not list FTTC, a label that gets used in different ways in different countries. Here in the UK it is usually stuck on a DSL service.
Ask your ISP what modems are compatible with its FTTC service.
Here's another good place to look for advice:
rhys375 wrote:
Meanwhile, the include free TP Link router is plug and play and works 100% perfectly. Any help would be greatly appreciated
Does it have a model number?
It is probably a modem/router. Does it have a setting to turn it into modem only (bridge) mode? If so you can put it in front of your RAX80. YOu dontl want two routers on the network.
Two routers on your network can cause headaches. For example, you can end up with local address problems. Among other things, the other router can misdirect addresses that the Netgear router usually handles, such as routerlogin.net or the usual IP address for a router, 192.168.1.1.
This explains some of the other drawbacks.
What is Double NAT? | Answer | NETGEAR Support- rhys375Tutor
Hi,
Thanks for your reply,The NBN Co in Australia provides an NCD device that decodes the VDSL signal and provides an ethernet signal essentially. I have read all that I need is a modem that is able to provide PPPOE information to authenicate with my ISP. So I believe that this router should be compatible but I just cant get the darn thing to work.
I have disabled the wifi signal from the TP Link and am currently using the Netgear as a wifi AP due to its improved range, wifi 6 compatibility and faster speeds. But if all its doing is extending my wifi there are cheaper solutions than what is essentially a top of the line consumer grade router.
I am sure that there is just a setting somewhere that I need to alter to get this working but after hours of much around I still cant get it to work...
Oh and the TP Link router that I have is the Archer VR1600 V2 if that matters
rhys375 wrote:
The NBN Co in Australia provides an NCD device that decodes the VDSL signal and provides an ethernet signal essentially. I have read all that I need is a modem that is able to provide PPPOE information to authenicate with my ISP.That bit is internally inconsistent.
If the ISP provides "an Ethernet signal" you do not need a modem. Modems are there to take whatever delivers the service to your home and to turn that into an Ethernet "signal".
If the ISP really does deliver Ethernet, a router alone should be enough. It is then up to the ISP to tell you what settings to use.
But if this is Ethernet to the house where does this come in?
What is that tp-link box thing there for if you already get Ethernet.
There are some common things going on in a different discussion about NBN. Perhaps reading the other one would help you too.
Re: Faulty Firmware for D7800? - NETGEAR Communities
We seem to have two people trying to use completely different Netgear devices into their NBN networks. One through a modem/router the other through a router.
Here's a test.There's a wire going from the outside world into your tp-link box. What happens if you plug that wire into a PC instead of the tp-link?
My main conclusion from these saga is that not only have Australian politicians made a pig's breakfast of this NBN initiative, but also its communications with customers has been abysmal. "My NBN won't work" is one of the most common discussions we see around here. I can't believe that this is all down to the customers.
