rsun0525
Aug 29, 2023Guide
Multi-Gig Port (Port 5) only detecting at 1gb speed?
I have a RAXE500 where I enabled the the multi-gig port as the Internet uplink but for some odd reason it's only detecting the port at 1GB. When I plug a 2.5GB device into that same cable, it works at 2.5GB, just when I plug it into port 5 on the RAXE500 it only shows up as 1GB. Is there some bug with autodetection or is there some other hack I can do? I put the latest firmware on it and have reset it to factory defaults and set it up again, but can't get it to detect the proper speed.
What device are you plugging into the multi gig port?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
- rsun0525Guide
Netgear M4250-12M2XF (MSM4214X)
I've got cat 6 cable, and when I've plugged other device into that port (eero 6e pro and Asus ZenWiFi Pro ET12), it correctly negotiates as 2.5GB.
Just to confirm, I should leave "Ethernet Port Aggregation" to Disabled right?
If other devices connect correct to the multi gig port and the M4250 does not, seems to point to the switch rather then the router. The RAXE auto detects the speeds based on correct cabling connection and supported connection rate speeds of the connecting devices. There is no setting to set the multigig port.
Yes.
What do you have connected to the Yellow Internet Port on the RAXE router?
- rsun0525Guide
One more question when I go into the Nighthawk app on my phone, under Settings, Router Settings, Internet Port, for "Type" is says Down, what does that mean? Is there a doc that details what the Types could be? Can't find any other setting in the mobile app or web configuration page that could be related to trying to get it to negotiate at 2.5GB
