axaxax's avatar
axaxax
NAT loopback stopped working (RAX30)
I have been happily using my RAX30 to access a server on my home network, but yesterday it stopped working.
I can access the service using a local IP address, but when I use its public domain name or my public IP, I get no response.
curl says:
connect to w.x.y.z port 80 failed: No route to host
It is the same on all machine in my house, but when I disconnect my phone from the wifi so it uses mobile data, the server works perfectly.
Does anyone have any ideas why?
I have tried:
* rebooting the router
* unplugging and re-plugging the router
* downgrading the firmware
but none of them help.
Thanks for your help!
  • Of course, as soon as I posted this I found the problem!
    NAT loopback was working fine, but the local IP address of my service had changed, so my port forwarding rule was pointing to the wrong IP.
    I have added an address reservation under LAN Setup to prevent this happening again.
