Retired_Member's avatar
Retired_Member
Nov 14, 2021
Netgear Alexa Skill showing "Device is unresponsive".
RAX200 with Firmware Version V1.0.5.132_1.0.69.
All other Alexa skills/devices work perfectly fine, but the Netgear router always shows unresponsive.
I've tried other firmwares as well.
Alexa has the Netgear skill properly added and my router is connected.
The router serial number in the description even matches correctly, and the network names show up, how "Device is unresponsive" and cannot control through Alexa.
Any ideas?
Am I missing some sort of port forwarding?
  • plemans's avatar
    what modem/gateway is the RAX connected to?
    I've seen the alexa devices/skills perform poorly in double nat situations
    • Retired_Member's avatar
      Retired_Member
      I’m not entirely sure the modem the ISP uses, I don’t have access to it, however the cable that runs from it goes to a POE with no serial number / product identification of any sort, and then the cable from that goes to my RAX 200.
      I also use a static IP.
      • plemans's avatar
        Not trying to be rude but that doesn't help much.
        If you want to get the alexa services running (not a big deal), we need full info on the setup.
        Again, its because many iot devices have issues with double nat's.
        If you're not worried about it working, then I wouldn't worry about it.
        If it is something you want working, we need to look into what you're actual setup is and the devices connected.
      Retired_Member
      I’m not entirely sure the modem the ISP uses, I don’t have access to it, however the cable that runs from it goes to a POE with no serial number / product identification of any sort, and then the cable from that goes to my RAX 200…
        Retired_Member
        Oops double post due to lag. No idea how to delete.
