aesop-riddle's avatar
aesop-riddle
Netgear AX1800 not blocking
I have a Netgear AX1800 WiFi Router RAX10.
I cannot block any websites. When I inquired, I was told to use the app. I do not want parental controls, I want to be able to block sites. Every router I've ever had allows me to do this with no problem.
If the router cannot do this without using parental controls through an app, then advise on a router that can.
Thanks
