crsb1960's avatar
crsb1960
netgear ax1800
Netgear ax1800 power light blinks. What is the problem? Can anyone help with this?
  • FURRYe38's avatar
    AX1800 is a wifi speed. What NG product and model# are you referring too?
    Review the user manual for LED behavior and indications.
      • michaelkenward's avatar
        michaelkenward
        Bbtbbt wrote:
        RAX10
        That's one question answered.
        How about all the other details people have asked about?
        You can help people to help you by providing the information suggested in this forum's header:
        Subject (Include model number and brief summary)
        Model (Recommended - Helps the community give the best answers)
        Body (Include additional detail including model version, firmware, OS and environment where relevant.)
        They are there for a good reason.
    michaelkenward
    When you turn a device on, it goes through a self test cycle.
    As a rough guide:
    • It blinks as it does some tests
    • After a bit it then turns to a solid colour, usually white or green
    • Wrong colour (red rather than white/green), or blinking = trouble
    • crsb1960's avatar
      crsb1960
      Netgear 36.  Blinks on start up but it still blinks after boot is complete.
      • FURRYe38's avatar
        Netgear 36 isn't a model #. Do you have a RAX### or EAX### something?
