Maryan
Oct 11, 2020Aspirant
NETGEAR Nighthawk AX12 and UK ISP Setup
Hello everyone!
I have a question regarding proper connection for AX12 router in the UK.
As we know in the UK we have VDSL & ADSL connection, so we need to use modem in order to be able to connect a WIFI router or combined modem/router in order to have an WIFI connectivity.
So, what I did many years ago I have removed my ISP Opereach DSL modem and BT HomeHub WiFi router, and purchased DrayTek Vigor28050N VDSL router in order to achieve more reliable and stable connection packed all in one device.
Years passed by and the router is not handling all connected devices properly, rebooting itself with no reasons, and dropping the connection, so this is the last bell to upgrade my network setup.
Recently I have changed my ISP from BT to Vodafone, but this is all the same, still Openreach phone line + new router which is Huaweii HHG2500 VDSL & ADSL (now also all in one device)
So, I would like to get NETGEAR Nighthawk AX12, but this is not a VDSL & ADSL router, so please advice me how to connect this router to my network to have a solid liek a rock connection?
Do I need to use this Huaweii router/modem in order to connect Netgear Nighthawk AX12? Will this device be strong enough to provide a stable connection to the Netgear router?
I don't trust those cheap devices, and I would like to have 100% reliable connection which will work like a beast.
So, maybe better sollution is to use Netgear ADSL2+ Broadband Modem like DM111PSP instead the Vodafone one?
This router should also resolve all my WIFI issues with the dead zones, and this is what I'm hoping for as well, but if not, will this router work with netgear nighthawk extender?
Many Thanks for your time and hoping to get an good recommendstion from you gys.
Kind Regards
Sounds good, try both and I might keep them both just in case one went down.
- MaryanAspirant
I forgot to mention I need a good router for gaming too so hope this AX12 will be a good choice or if not please let me know your recommendation from Netgear Nighthawk router range.
Thanks so much!
- Christian_RNETGEAR Employee Retired
Hello Maryan,
Welcome to the community! Did you end up getting the AX12 router?
Christian
- MaryanAspirant
Hi,
Thank you for your answer.
No, I didn't decied yet. In 26 October I'm moving my broadband to BT, so they going to send me a brand new BT Smart Hub which I can use as a modem.
Then I can connect it to AX12, but I'm not too sure if this is a good setup example.
Maybe I will need an other good modem (just modem) before AX12 instead of BT Smart Hub Router.
This is why I asked the question here as Netgear community knows best what should be the best one.
All I need is to have a rock solid connection and good network range.
I was also thinking about adding a mesh extender like EX7700.
Many thanks
- psychopomp123Luminary
OP, just get a Draytek 130 VDSL modem and hook that up to the router of your choice, eg Netgear AX12. I'm also in UK and using the AX12 on my BT FTTP line and its the best router I've ever used for wifi range & coverage. Buy it, you won't regret it!
- MaryanAspirant
Thanks guys, yes the AX12 seams to be one of the best when come to the WiFi range and features I need for gaming.
Thanks for all the advices! Seams that HG612 and Draytek 130 are only raliable modem solution for this time in UK.
I have read a lot recently regarding Draytek 130 and users who was testing it against HG612 and the results was pretty the same.
HG612 had a slightly better performance, but I think I will get them both and test them for myself. The winner will stay with me for good, the looser will go back on eBay :)
- NewfiedroolVirtuoso
