Xiong's avatar
Xiong
Netgear Nighthawk AX12
The router frequently disconnects, prompting no IP address, unable to connect to the IP for a long time
  • plemans's avatar
    What firmware is on the router?
    What modem/gateway is it connect to?
    When it disconnects, is it wired devices, wireless devices, all devices?
    Does it say "connected, no internet" or does it drop off the network entirely?
    Have you tried a simple factory reset and reinstall? The RAX devices got quite a few firmware changes and have responded well to factory reset/reinstalls.
    • Xiong's avatar
      Xiong
      Ax12 is the latest firmware. I can’t connect to the network but the Wifi is connected normally. If there is no network, the router needs to be restarted for normal operation. The same problem exists when I restore the factory settings.
      • plemans's avatar
        Xiong wrote:
        Ax12 is the latest firmware.---no its not. AX12 isn't a firmware number. I can’t connect to the network but the Wifi is connected normally----This makes zero sense. you can't connect but you can connect?. If there is no network, the router needs to be restarted for normal operation. The same problem exists when I restore the factory settings.
        And the other info? LIke modem/gateway?
        Please make sure to be details and precise. We aren't there to see what you're doing/done.
