Anonymous's avatar
Anonymous
Mar 27, 2024
Netgear nighthawk rax41 ax3600 router
Starlink is my internet provider.i put starlink in bypass mode setup the nighthawk router and I have a wired connection to my xbox series x console.I went into nighthawk router setting did auto configuration for ipv6 and tested the NAT on xbox it gave me a double nat at first now it says open but xbox is slow now running these test and if I'm not mistaken the latency has went higher.I guess what I'm asking could anyone help me out with setting up my nighthawk with proper setting to game.....TIA
  • FURRYe38's avatar
    If you have the ISP modem in bypass or DMZ there for the RAX router, and xbox is getting OPEN NAT, then this is the best you can get. You should be able to get OPEN NAT with or with out IPv6.
    Recommend using a ethernet connection to xbox for best performances in gaming.
    Try connecting the xbox to the ISP router to compare results.
    • Anonymous's avatar
      Anonymous
      Now xbox says ipv4 and ipv6 open nat and I haven't been kicked outta race on forza like I was before replacing starlink router.I just want to make sure all was good on my end because I have never had to deal with any of this before.Should I disable the ipv6 auto setting or leave it be.
      • FURRYe38's avatar
        Leave it be.
        Something to ask the ISP about to see if you can remove there router and put the RAX in place of it. They will have this information.
