thegadgetguy
Dec 02, 2021Aspirant
Netgear RAX80 and Amysen / any other similar smart socket / plug and Smart Life App
Having an issue with new smart plugs trying to add to app / network.
So I bought the same brand a year ago (at the time I had an older Netgear 2.4/5GHZ Router) and they connected no issue with Smart Life App.
Now I have been through 3 sets of plugs and realize its not the plugs / sockets but maybe something I am not doing with router to de-emphasize 5GHZ and strengthen 2.4.
I have done the following:
- Tried connecting with 2.4GHZ on phone wireless and app connection and nothing
- Tried AP and the suggested names didnt even show up in my list of APs
- Tried reducing the transmit power control to 25% for 5GHZ and nothing
- Have also tried hiding 5 GHZ SSID and nothing
- Have tried lowering the mode on 2.4 Ghz to 54MBps and nothing
Have checked some other knowledge bases and cant seem to find a solution. Amazon must think I am crazy buying and consequently returning them over and over again. HELP would be greatly appreciated!
Might try disabling Smart Connect if enabled on the router and separate the SSID names.
Try changing channels, 1, 6 or 11 on 2.4Ghz.
Netgear has set up a community forum specifically for the NightHawk RAX WiFi 6 Router products. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/bd-p/en-home-routers-nighthawk-wifi-ax6
Thank you.- thegadgetguyAspirant
So Smart Connect is not on, but will try changing the Wifi SSID. Right now they are just separated by 2.4 or 5 but the name is the same, meaning network 2.4 and network 5g (for example). Are you suggesting i change the name completely to something else to test this?
Should I throttle it down to 54mbps as right now under 2.4 its set at "up to 1200 mbps"?
Ok so tried changing SSID for 5 ghz to something comepletely different and still nothing.
Have switched from Channel 1 to another Channel and still nothing.
