sachb
Oct 17, 2022Tutor
Netgear RAX80 UPNP still not functioning correctly (V1.0.10.140)
Hello Team Netgear, I have upgraded my Router to the latest firmware as of the time of writing this, and the problem of UPnP still persists.
Here ismy configuration:
OS: Windows 11 Pro
PC: Asus K571
Wifi card: Intel AX210 NGF
Router Model: Netgear RAX80 (1.0.10.140)
App: Bitcomet 64 bit
Problem: Port Forwarding doesn't work even with the latest firmware (1.0.10.140)
The router attempts to include the port forwarding rules in the table but nothing happens on the client side i.e the Laptop.
I have confirmed that the Firewall is turned off, and have tried my 2nd router. The 2nd router correctly forwards the port and I see a Green status on the application (Bitcomet) but on the Netgear RAX80 it's always on Yellow Status which is blocked.
Hope the fix will be available soon with either a firmware update.
Thank You
Did you disable uPnP before setting up any PF rules?
- sachbTutor
Manufacturer is Huawei as far as I know, ISP is Etisalat. However, I don't think it's the modem, cause I have the Netgear R7800 and that worked without any issues connected to the same modem.
The UPnP was working on Netgear R7800, but as I replaced the router to RAX80 the UPnP failed to work.
I believe the firmware is at fault here, cause using another router gets me what I want.
I have another router in the room, Asus AC86U whose IP is set on DMZ on the Netgear RAX80 router and the app shows up in green, which means Asus is also forwarding the ports correctly through UPnP.
The brand of your modem and the ISP tell us nothing useful about the device itself.
Sadly, just because it once worked does not mean that the modem is not involved.
Here's why. When you set up a new router, it can detect the modem/router in front of it and set itself up accordingly.
Unfortunately, it you go through the process again, it may not work and the R7800 gets lost..
If you really want informed help, then it might be a good idea to answer the question from FURRYe38 . It shouldn't be too difficult t look at the thing and read off the model number.
This may prove to be irrelevant, but there's no harm in satisfying our curiosity.
