miclin's avatar
miclin
Nightawk AX8 AX6000 WiFi router cannot connect always
Hi,
I always cannot connect my wifi router, e.g. I chose 5GHz network, can use WhatsApp only but I browsed website not successful, then I turned to 2.4GHz can use a while, but browsed other page then not connect, please help
  • plemans's avatar
    What modem/gateway do you have?
    What firmware is on the RAX?
    Does this always happen?
    Is it only happening on 1 device or all devices?
    Does it happen to devices that are hardwired in?
    • miclin's avatar
      miclin
      RAX80 AX6000
      V1.0.3.106
      Yes
      All devices
      No, problem in all devices included iPhone, iPad, Apple TV and Xbox
      • plemans's avatar
        The RAX is the router. what modem/gateway is it connected to?
        Have you tried a factory reset and a clean install?
