GlenD
Apr 12, 2022Tutor
Nighthawk AX12 BRS_wanlan_conflict.html
Since moving into my new residence this router has started blocking access to multiple website sites and is continuously asking for an admin login? Can anyone advise as to what settings I need to cha...
Apr 12, 2022Guru - Experienced User
1. what firmware is on the router?
2. what modem/gateway is it connected to?
3. you said this started when you moved to a new residence. It didn't happen at the old one? What changed during the move?
GlenD
Apr 13, 2022Tutor
Hello Mate,
I'll start with I'm in Australia with Telstra.
Ans:
1. V1.0.1.122
2. Telstra Fixed Wireless NBN ( I think that's the answer you're looking for?)
3. Nothing that I'm aware of, I had the Wireless NBN at the last house and had it put on here...
Cheers
GD
- plemansApr 13, 2022Guru - Experienced User
what wireless nbn connection device does it use?
Do devices directly connected to the nbn connection work?
You might try updating the routers firmware. the latest for the RAX120 is 1.2.3.28
Just make sure to get the correct version as theres a v1 and a v2.
