t10bender's avatar
t10bender
Nighthawk AX1800 (RAX10) wifi router
My current set up: Nighthawk AX1800 (RAX10) wifi router, connected to a Netgear wifi cable modem. If I want to add the Mesh 6 system, do i need to:
replace the Mesh 6 router with the existing RAX10 wifi router?
Can I add the new system to the existing set up?
If so, do I connect it to the cable Router?    Or to the RAX10?
Assuming either way, it becomes a completely different Log in point, with its own credentials for logging in?
  • plemans's avatar
    How many satellites do you want?
    Reason I ask is if you're only needing one, they make mesh extenders that work well. but if you're needing more than 1, its better to switch to a full mesh system.
    How big is your home?
    You put you have a RAX10 and a cable modem/router device. What cable modem/router is it?
    • t10bender's avatar
      t10bender
      The cable modem is Netgear. The Nighthawk AX1800 router wifi is hooked to it.
      Since my post, I ended up connecting the Mesh Router to the Nighthawk wifi router. And created a separate wifi system for the house. Long work around. However, it works......
      I want to add one more satellite. I add, I bought 2 of the MK62 box systems from Sam's.
      Soooo......
      as noted above, I have a mesh router system set up, and working. Now I'm trying to add the other satellite, that I took from the other 2-piece system. Hence, I will not use the other router except for a doorstop.
      Now I cannot get the additional satellite, from the other box, to sync up with my current 2 pc system????
      • michaelkenward's avatar
        michaelkenward
        As plemans asks, which cable modem?
        Which Mesh router? An Orbi?
        Are the MS60 satellites compatible with whatever it is? They are designed for the MR60 router.
        You can just slap together a random selection of routers and satellites, especially in Mesh systems, which rely on coordinated communication between routers and satellites.
        Or an access point?
