LadyAlf
Jan 27, 2025Aspirant
Nighthawk AX2400 wi-fi password incorrect
I have had this router for 3 years and all of a sudden the password for my 2.4ghz is incorrect. I can log into the 5G but not the 2.4, and several devices rely on the 2.4. I logged into the app and verified the password is correct. Any help would be greatly appreciated.
try logging in through the browser. Change it to something else and then change it back.
Are you using smart connect?
- LadyAlfAspirantHow do I log into the browser? I have the Nighthawk app. What is smart connect?
You log into the browser using its ip address.
Smart connect combines the ssids for 2.4ghz/5ghz into a single ssid. In that mode, they don't show up as separate but the same network. It allows devices to bandsteer between the 2 bands as needed.
