Voymetra
Apr 17, 2020Aspirant
Nighthawk AX4 RAX35 not letting Ring Stick Up Camera to connect
Aloha from Hawaii,
The router I'm using is a Nighthawk AX4 RAX35 with firmware V1.0.3.62_1.0.1
I have tried to install 3 RING battery powered Stick Up Cameras to add to my 2 RING Wired Spotlight Cameras already installed.
The 2 Spotlight cams connect to my Nighthawk AX4 router with no problem.
The 3 Stick up battery cams are all having trouble connecting saying it is too far from the router which is only 2 feet away!
I've worked with RING's tech and we troubleshooted for 2 hours with no success.
RING sent me 3 new cameras and now they all still do the same thing!
The 2 RING spotlight wired cams are still chugging along with no problems with connecting to the Nighthawk.
I've tried using a guest network I created with no luck.
I've also looked at a discussion here to turn off AX in wireless setup to help but didn't work.
Anyone can help please.
Thank you!
- Christian_RNETGEAR Employee Retired
Hi Voymetra,
Welcome to the community! May you try disabling Smart Connect in the router's settings.
Christian
- VoymetraAspirant
Hi Voymetra,
My apologies, I meant traffic meter and not smart connect. I've included the user manual linked below and you may refer to page 60 on how to disable traffic meter.
http://www.downloads.netgear.com/files/GDC/RAX35/RAX35_UM_EN.pdf
Christian
