Skorpion's avatar
Skorpion
Follower
Mar 25, 2021
Nighthawk AX6 AX5400(RAX50) Change device Name for attached devices
Hello
As there is no possibility to change the device name of attached devices by my old Router WNDR4500 (sometimes only the MAC-Adress is shown) my question now:
When I buy Nighthawk AX6 AX5400(RAX50) is it possible to change the device name of attached devices for better identification?
Many thanks for your help in advance
1 Reply
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    Hello Skorpion,
    Yes, you may do so using the Nighthawk app or visiting the GUI as routerlogin.net.
    Christian
