Dustin_V
Dec 17, 2018NETGEAR Employee Retired
Nighthawk AX8 8-Stream WiFi Router - Buyer's Guide
With the influx of smart home devices on the market making their way into our homes, one thing we tend to overlook is the infrastructure that supports it. From smart speakers, security cameras...
- Nov 09, 2022
Admin marked as SOLVED
myersw
Jan 02, 2019Master
Does the laptop support AX? I suspect not.
There are maybe one wireless hardware manufacturer that is making a chip that supports AX. AX is a coming down the road thing.
Folks let me know if wrong.,
delkoman
Jan 02, 2019Tutor
AX supposed to be backward compatible with all existing WIFI chipsets. The fact that I have a dozen or so older devices in my house that do not have the AX chip but DO see the SSID broadcas confirms the backward compatibility. It maybe the AX8 is only backaward compatible with some devices but not all and this needs to be addressed in an firmware update.
- myerswJan 02, 2019Master
Backward compatible can be iffy when the standard is not even finalized yet. So I am not surprised that a device does not work. Until there are clients that support AX I would turn it off.
