ozipin
Jul 14, 2022Follower
Nighthawk AXE11000 still have issues?
I just ordered a new Netgear Nighthawk RAXE500 WiFi 6e AXE11000 for $370. It was a Amazon prime day deal. I was reading reviews and it seems it has an issue where it’s always dropping connection and rebooting itself due to over heating. It seemed most of those reviews were from the wifi 6 version of this same model but I was wondering Is this still an issue? Should I cancel and get the new $200 TPLINK Wifi 6e router? Also I was planning on using a Netgear CM1200 or CM2000 modem. Do these have any issues? Or is there a better option?
Sort By
i've got an RAXE500 and its worked great.
You'll always find some bad reviews and issues on the forums because thats where people with issues go.
And amazon has a pretty great return process. So I'd keep in (got a good deal on that router) and see how it works.
If you're having issues, return it because you'll probably not trust it after reading reviews.
