AddisonGeek's avatar
AddisonGeek
Nighthawk AXE7300 Tri-band WiFi 6E Router (RAXE290)
As I purchased the router and registered it in November 2022, how much longer is it going to be supported with firmware updates?
Also, is there any possibility that open-source firmware will be allowed?  Given the current climate on the importation of routers, my concern is that I will have limited options in the future if I need to replace it.
  • FURRYe38's avatar
    Can check here or EoL status:
    https://www.netgear.com/about/eos/
    Nothing lasts forever.
    Keep checking NGs download site for updates.
    Can always load 3rd party FW on NG routers for those parties that develop and support NG model routers. Will have to check with them to see what they support.
  • Rather than taking the router to the local electronic recycling center, it would be nice if Netgear would allow open source firmware for EOL models.  I realize that it might cut into the income stream by forcing end users to purchase new devices, yet for the tech savvy, it would be a goodwill gesture.  I have flashed older models, and I realize there may be proprietary code involved that may transcend models, thus locking us out of open source solutions.
