ricktgray
Sep 23, 2020Aspirant
Nighthawk RAS35 not resetting
I changed ISPs and needed to reset the Nighthawk. Pressing the reset button for seven seconds looks like it power cycles and resets it but doesn't. Constant red blinking power light, rare flashing amber 2.4 light, one LAN light stays lit for a bit then drops with a cable connected to my computer and occassionally all lights blink once. Connected to both my new ISP modem and my computer, ethernet connection drops and reconnects constantly. For a few seconds I see the old name of the SID i gave it with the old ISP indicating that the reset button is doing nothing. Cannot connect using the IP assigned by the new ISP modem (seen in the modem itself) or the IP gateway seen on the computer or routerlogin.net. The webpage states either the network cable isn't plugged in (Nighthawk drops it constantly) or give the generic Netgear page of not being connected to the router. The app and computer doesn't see any wifi SID with either the generic NETGEARXX or the name I gave the it for the old ISP.
Does any one have any suggestions on making it reset? My warranty is past the 90 day mark and if it can't be reset then I have a $175 doorstop.....
- ricktgrayAspirant
Update: I tried the 30 30 30 reset which seems to work with nothing plugged into the ethernet ports. The second I plug either the LAN from my modem or from my computer, the Netgear resets and will not connect back to the modem. The power light stays red the starts flashes then back to red. I see connectivity to my computer on the led and see it connected in my Windows connecttions but even though I am connected wirelessly to my wifi home network, pulling up the routerlogin.net gives me the error I may not be connected blah blah blah. Using the app it cannot obtain an IP using my Netgear password on the bottom of the router.
- Christian_RNETGEAR Employee Retired
Hello ricktgray,
Were you able to sort this out? I would recommend opening a ticket with support and request for a hardware check.
Christian
- ricktgrayAspirant
I have found no solution and thave opened a ticket but then realized I would have to buy extra support for about half what the router costs to receive an answer so I have basically dropped this issue.
