Retired_Member's avatar
Retired_Member
Jan 07, 2021
Nighthawk RAX 50 have to reboot several times a week
Several times a week I have to reboot my router.  All the lights show it is woking, however; I won't have internet.  A few days ago it seemed to do a factory reboot by itself and I had to repogram all my connected devices (smart connect was on, but still had to enter passwords).
  • Dan32's avatar
    Dan32
    Jan 10, 2021
    Try a PC using ethernet cable attached to one of the 4 LAN ports.  Although, if that works, it just confirms wireless has a problem.
    At any rate, best to just return it and exchange it for another for the least hassle.
    My 1st RAX50 was similar, I did return it for a refund (BB)  and just bought another RAX50 a month later (at an even better sale price), just to be sure it came from a different batch.  it's been up non-stop with heavy usage from a wide range of various devices for 3 or more months now.
  • plemans's avatar
    What modem/gateway do you have?
    What firmware is on the router?
    is it only wireless devices or do wired devices drop as well?
    • Retired_Member's avatar
      Retired_Member
      Fiber modem provided by Aerux broadband
      v1.0.2.72
      No internet at all (wired or wireless)
      • plemans's avatar
        Retired_Member wrote:
        Fiber modem provided by Aerux broadband---which modem/gateway model is it?
